I’m working on a project where users need to be able to update and add contact information. Users can add as many means of contact or social media information as they want. I have a schema that looks like:
I want to be able to send to the backend only the contactInfo data that the user provides, so I’m trying to do that using $arrayToObject. The problem that I’m having is that when I using this with $set its deleting/ ignoring the previously saved data. Here is an example of the issue: mongoplayground. I would really appreciate any help or advice on how to fix this. Thank you!
I think we are missing some facts about your use-case.
Why do you use $arrayToObject? How is your array of k/v values built?
I think that sharing the code around your update could lead to more specif recommendation. The reason why the other fields are removed from contactInfo is that you $set the top field contactInfo. Basically, you request to change the object contactInfo with the result of $arrayToObject. Using the dot notation as shown by Samuel_84194 is the way to set sub-fields inside an object without losing the other sub-fields.
If you have no choice and you receive the array as you shared then you would need to use reduce on this array to convert it to the dot notation.
