I have created a function in Atlas function and created an HTTPS Endpoint to insert some data,
but how to get the body in the post request. I am getting query parameter in the request but body is not there.
import moment from "moment";
exports = function ({ query, headers, body }, response) {
return {
status: "ok",
bodyy:body,
query:query,
response:response
This is the response I am getting when hitting Post request with body.
Please confirm if my understanding of your use-case is correct? You are sending a Post request to your function in Atlas and it has a return statement where the body of the request should be returned but instead you are getting a base64 encoded value of the parameter in body.
If yes, then, can you please confirm if you want to just insert data or you also want to read inserted data from the Post request?
Additionally, the response you shared in the bodyy. It consists of binary datatype whose Canonical representation is as below
Base64 encoded (with padding as “=”) payload string.
"<t>"
A one- or two-character hex string that corresponds to a BSON binary subtype. See the extended bson documentation BSON (Binary JSON): Specification for subtypes available.
If you change the return statement to below, you will be able to see the body sent in your POST request
