Consider the following collection
{_id: 0, status: 'pending'},
{_id: 1, status: 'pending'}
If I run the following operation twice concurrently I would expect to get both documents set to processing and returned
findOneAndUpdate({ status: 'pending' }, { $set: { status: 'processing' } })
However what I experience is that the first document is updated and returned twice. Am I misunderstanding something?
Hello @Andreas_Hald ,
Welcome to The MongoDB Community Forums!
I added the mentioned documents and ran the same query twice below is the response I got
db.collectionA.findOneAndUpdate({ status: 'pending' }, { $set: { status: 'processing' } })
_id: 0,
status: 'pending'
_id: 1,
status: 'pending'
So, it is working as expected, if the two queries run one after another.
By concurrently , do you mean you’re trying to run/update the same document with two queries at the same time? Could you post an example code that can reproduce what you’re seeing?
Tarun
Kobe_W
(Kobe W)
March 16, 2023, 4:47am
#4
FindandUpdate should be atomic operation. Maybe explain a bit on how you run your tests.
