How to connect to MongoDB using Nodejs, Expressjs
I’ve been struggling with connecting db to expressjs server.
I googled for a solution and find this official doc:
The instruction is good but its js code is not specialized for nodejs(It’s using import so it’s specialized for web coding, I thought so =D)
Any idea?
Node js supports import, since many years back. What version of nodejs are you working with?
DO NOT USE THIS TUTORIAL
The GitHib repo this tutorial has you clone does not include all the files needed. The tutorial should be updated or taken down.
