Hi. Who knows how to check the current setting of TTL?
Welcome to the MongoDB Community @Steven_Yu !
Time-to-Live (TTL) indexes are defined per-collection based on a provided expireAfterSeconds value. By default collections do not have a TTL index.
You can use the db.collection.getIndexes() helper in the MongoDB Shell to get index information, for example:
test> db.eventlog.createIndex(
{ "lastModifiedDate": 1 },
{ expireAfterSeconds: 7200 }
lastModifiedDate_1
test> db.eventlog.getIndexes()
{ v: 2, key: { _id: 1 }, name: '_id_' },
v: 2,
key: { lastModifiedDate: 1 },
You can modify the expiry for a TTL index using the collMod command, for example:
test> db.runCommand({
'collMod': "eventlog",
index: {
keyPattern: { "lastModifiedDate": 1 },
expireAfterSeconds: 3600
expireAfterSeconds_old: Long("7200"),
expireAfterSeconds_new: Long("3600"),
ok: 1
If that isn’t the information you are looking for, please provide some further details on your environment:
- MongoDB server version
- Driver/tool version you are using to display TTL details
- TTL information you require
Stennie
