I have a use case where I need to join two collections in MongoDB but the join must happen only if one of the two conditions are met.
The SQL equivalent query is given below. How can I translate this in MongoDB?
SELECT *
FROM MainTble i
Left JOIN SecondTable p
ON CASE
WHEN i.myPropert="SMS" and i.phoneNumber = p.phoneNumber THEN 1
WHEN i.myProperty="Email" and i.email = p.email THEN 1
ELSE 0
END = 1
@MWD_Wajih_N_A ,
The following pipline does the trick:
db. MainTble.aggregate([{$lookup: {
let: {"phone" : "$phoneNumber", "email" : "$email" , "property" : "$myProperty"},
pipeline : [{ $match: {$expr: {
$or : [ { $and : [{$eq : ["$$property" , "SMS"]},{$eq : ["$$phone" , "$phoneNumber"]}]
,{ $and : [{$eq : ["$$property" , "email"]},{$eq : ["$$email" , "$email"]}]
as: 'messages'
Pavel
Thank you. It was helpful
