So I have a situation where I need to delete elements in an array of reference / ObjectIds, but the delete condition will be based on a field in the reference.
For example, I have the following schemas:
const UserSchema = new mongoose.Schema({
firstName: String,
lastName: String,
homeFeeds:[{type: Schema.Types.ObjectId, requried: true, ref: "Activity"}];
}); // User , is the referenece name
const ActivitySchema = new mongoose.Schema({
requester: {type: Schema.Types.ObjectId, requried: true, ref: "User"},
message: String,
recipient: {type: Schema.Types.ObjectId, requried: true, ref: "User"},
}) // Activity, is the reference name
Now I need to delete some of the homeFeeds for a user, and the ones that should be deleted need to be by certain requester. That’ll require the homeFeeds (array of 'Activity’s) field to be populated first, and then update it with the $pull operator, with a condition that the Activity requester matches a certain user.
I do not want to read the data first and do the filtering in Nodejs/backend code, since the array can be very long.
Ideally I need something like:
await User.find({_id: ID})
.populate("homeFeeds", "requester")
.updateMany({
$pull: {
homeFeeds.requester: ID
But it does not work, Id really appreciate if anyone can help me out with this?
