Hello. I have been strugling with this for days now so hoping someone can help me. I have a free plan on Atlas abd i’m trying to get a dump of my database via the CLI but failing every time. Atlas says I can use the command:
Post a screenshot of what you are trying that shows the issues you are getting.
Without an exact error message we cannot really help.
Just in case, and are placeholders and must be replaced with your real admin user password and a real database name. It is the safest to use test as the database name if you are unsure.
If I post a screenshot it will reveal my connection info so i’ll paste from the command line below
I have now followed the instructions on this page to install the Mongo database tools
I then try the following command along with the equal sign, thank you
mongodump -uri=‘mongodb+srv://<MY_USER>:<MY_PASS>@cluster0.lab0q.mongodb.net/’
I then get
2021-01-09T05:22:28.859+0000 warning: Failed to connect to 127.0.0.1:27017, reason: errno:111 Connection refused
My Linux box has 27017 outbound allowed. My application wouldn’t work without this. And I have set up Atlas to allow connections from this IP, again my app wouldn’t work without this. So I’m not sure why it is saying “connection refused”
