I have installed mongodb via homebrew added it to my path variable via export (mac) and checked using echo(mac) but when I run mongo “mongodb+srv://discordbot.5vftj.mongodb.net/myFirstDatabase” --username areze I get the error bash: mongo: command not found can anyone help because I really need this database.
Welcome to the community!
Please show the output of echo $PATH command
Can you invoke mogo command from bin directory or by giving full path of mongo.exe
fOR THE PATH I GET:
/Library/Frameworks/Python.framework/Versions/3.9/bin:/Library/Frameworks/Python.framework/Versions/3.8/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/git/bin:/Library/Frameworks/Python.framework/Versions/3.9/bin:/Library/Frameworks/Python.framework/Versions/3.8/bin
I don’t know how to do the second thing
I don’t see mongo in your path
What command you used to update path
by export method it will not be persistent
You have to update in /etc/paths
Where is your mongodb installed
cd to that dir.Under bin dir you will see mongo executable
Just run mongo --version to test if command working or not
