when create two indexes on a collection:
db.createIndex({“name”: “hashed”})
db.createIndex({“name”: 1}, {unique:true})
what is the behavior of this collection?
Actually, original problem is this:
first create an empty shard collection by : sh.shardCollection(“db”, {“name”: “hashed”})
which would create a hashed index on db with the field name, but also I want the field name to be unique
so I create another index by : db.createIndex({“name”:1}, {unique:true})
what’s the behavior of the collection?How the data of this collection arranged in shards, is it hashed or is it ranged?
(dont focos on the code, I omit the collection name , it’s just a simple example)
Hi @11115
Having a hashed and unique index on the same field is a valid strategy to have uniqueness enforced on a sharded collection, since:
- A value “x” will be hashed to another value, say “z”.
- Another value “y” can also be hashed to the same value of “z” (hash collision). This is fine for our purposes.
- You cannot enforce uniqueness on a hashed index.
- However if you create a unique index on the same field, you can enforce uniqueness on that field, in a sharded collection.
So using your example, you can shard the collection using ({“name”: “hashed”}) as the shard key to allow for semi-random distribution of documents across shards. However if you also would like to enforce that “name” should be unique, creating a unique index ({“name”: 1}, {unique:true}) should do that for you.
This is mentioned briefly in Hashed Index: unique constraint.
Best regards,
Kevin
