We are running our application in a Google Cloud GKE Autopilot cluster with VPC peering configured to a MongoDB Atlas (M10+) cluster. The connection generally works (e.g., through the Java driver and mongosh), but we are facing intermittent DNS resolution issues inside the app pods.
 Setup Details:
 Setup Details:
- Method of connection: Java Driver
- MongoDB Java Driver Version:  4.11.2
- Connection String Used:
mongodb+srv://user_name:password@mongodb-7-0-pri.xxxxx.mongodb.net/database_name?retryWrites=true
We’ve also tried with appended parameters:
&authSource=admin&tls=true&appName=mongosh+2.2.6
 Problem:
 Problem:
Even though the app is able to connect to MongoDB Atlas via the Java driver and mongosh, it occasionally logs exceptions like:
com.mongodb.MongoSocketException: Unknown host mongodb-7-0-shard-00-01-pri.xxxxx.mongodb.net
com.mongodb.MongoServerSelectionException: Server selection timed out after 30000 ms
com.mongodb.MongoSocketReadException: Prematurely reached end of stream
	Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.ts.services.app.InitializeDBs]: Constructor threw exception; nested exception is com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting for a server that matches ReadPreferenceServerSelector{readPreference=primary}. Client view of cluster state is {type=UNKNOWN, servers=[{address=mongodb-7-0-pri.xxxxx.mongodb.net:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketException: mongodb-7-0-pri.xxxxx.mongodb.net}, caused by {java.net.UnknownHostException: mongodb-7-0-pri.xxxxx.mongodb.net}}]
These issues seem to stem from DNS resolution failures, even though the app is deployed inside a properly VPC-peered GKE environment.
 Network & DNS Info:
 Network & DNS Info:
GKE Pod IP:** 10.xx.131.xx
GKE Cluster IP Range:** 10.xx.xxx.0/17
Service Type:** LoadBalancer (10.xx.0.207)
Seccomp Profile:** RuntimeDefault
Atlas Access List:** includes full cluster CIDR range
Peering:** Confirmed between GCP VPC and Atlas VPC
DNSPolicy:** Using GKE Autopilot default (ClusterFirst)
 Questions:
 Questions:
- Are there any known issues with mongodb+srvSRV record resolution inside GKE Autopilot?
- Would switching to a non-SRV URI with replica set members help improve reliability? (If yes, could you confirm the best format?)
- Are there any timeouts, DNS caching, or JVM-level settings we should tweak in the driver?
- What would be the recommended DNS configurations (e.g., dnsPolicy,dnsConfig) in GKE Autopilot to make SRV lookups reliable?
- Any troubleshooting steps or best practices for Atlas + GKE peered DNS issues?
Thanks in advance! We’d appreciate any insight into making this connection more stable and eliminating these DNS-related exceptions.
