I have multiple elements with unique: true in my user schema, and when i test out my api on local machine it works just fine, but when I host my api and then try to create a user the first user get created without any problem but all the other document throw this error even though i am using unique values.
MongoDB automatically creates these indexes and they seems to be causing the problem.
This is my user schema
const mongoose = require("mongoose");
const plm = require("passport-local-mongoose");
const jwt = require("jsonwebtoken");
const tokenSchema = new mongoose.Schema({
token: {
type: String,
unique: true,
required: true,
symbol: {
type: String,
required: true,
colony: {
type: mongoose.Schema.Types.ObjectId,
ref: "colony",
required: true,
amount: {
type: Number,
required: true,
default: 0,
const userSchema = new mongoose.Schema(
username: {
type: String,
required: [true, "Username is required"],
unique: true,
trim: true,
minlength: [3, "Username must be at least 3 characters long"],
maxlength: [20, "Username must be at most 20 characters long"],
tokens: {
type: [tokenSchema],
default: [],
colonies: [
ref: "colony",
default: [],
email: {
type: String,
required: [true, "Email is required"],
unique: true,
match: [
/^\w+([\.-]?\w+)*@\w+([\.-]?\w+)*(\.\w{2,3})+$/,
"Please enter a valid email",
{ timestamps: true }
userSchema.plugin(plm);
userSchema.methods.getjwtToken = function () {
return jwt.sign({ id: this._id }, process.env.JWT_SECRET, {
expiresIn: process.env.JWT_EXPIRES_TIME,
module.exports = mongoose.model("user", userSchema);
