dlabaja
(Ten dlabaja)
May 23, 2021, 10:11am
1
Hi, I need to find a document in my collection with some information about the player and if there isn’t any, insert a new one. I know in C# is FirstOrDefault(), which returns null if nothing is found. Unfortunately, in JAVA, the collection of documents cant be null. Is there some other way to do it?
Code I have so far: mongo - Pastebin.com
Hi @dlabaja ,
I guess the best way is to use a method such as FindOneAndUpdate with an upsert:true having only setOnInsert clause only.
This means that the document will try to be fetched and if not existing the upsert part of $setOnInsert will occur.
https://mongodb.github.io/mongo-java-driver/4.2/apidocs/mongodb-driver-sync/com/mongodb/client/MongoCollection.html#findOneAndUpdate(com.mongodb.client.ClientSession,org.bson.conversions.Bson,java.util.List,com.mongodb.client.model.FindOneAndUpdateOptions)
You can learn more on this article from my colleague:
https://www.mongodb.com/quickstart/java-setup-crud-operations/
Let me know if that helps?
Best regards,
Pavel
dlabaja
(Ten dlabaja)
May 23, 2021, 2:17pm
3
Hi, thanks for a fast response
I’m not sure if I understand it, this is my code so far
Bson filter = eq(“uuid”, event.getPlayer().getUniqueId().toString());
Bson updateOperation = push(“uuid”, event.getPlayer().getUniqueId().toString());
UpdateOptions options = new UpdateOptions().upsert(true);
Object updateResult = coll.updateOne(filter, updateOperation, options);
and log: log - Pastebin.com
Hi @dlabaja ,
What I suggest is to use findOneAndUpdate() method instead of updateOne:
Bson insertDoc = setOnInsert(“uuid”, event.getPlayer().getUniqueId().toString());
Document userDocument = coll.findOneAndUpdate(filter, insertDoc, options);
I haven’t tested this code and it is based on the Java article and API
This way if the document exists it will be returned and if not use setOnInsert to set a new document.
Best regards,
Pavel
dlabaja
(Ten dlabaja)
May 24, 2021, 7:02pm
5
Hi tried it but still getting MongoTimeout exception. It seems that it cant find the document, so it tries again and again until the exception
Hi @dlabaja ,
I actually think that your issue is with the Java version and your client certificate being out of date:
Issues connecting to Atlas Database - #4 by Pavel_Duchovny
See the above way to try and fix it.
dlabaja
(Ten dlabaja)
May 27, 2021, 4:26pm
8
Ok, it seems I solved it - using JDK 12 wasn’t a good option, so I updated it to 16 instead. Thanks for your support and have a nice day
system
(system)
Closed
June 1, 2021, 4:26pm
9
