I’m dockerizing MERN apps at the moment.
The apps is divided into 2, react app at frontend and express app at backend.
The goals is to enable hot reloading at the react app.
Here’s my docker-compose.yml file :
version: '3'
services:
mango:
container_name: mango
image: nginx:alpine
ports:
- 3000:80
volumes:
- ./docker/app/nginx.conf:/etc/nginx/conf.d/default.conf
- ./build:/usr/share/nginx/html
depends_on:
- mango-builder
command: "/bin/sh -c 'nginx -g \"daemon off;\"'"
logging:
options:
max-size: "10m"
max-file: "3"
networks:
- local_network
mango-builder:
container_name: mango-builder
image: node:12.13.0
working_dir: /app
volumes:
- .:/app
command: bash -c "rm -rf /app/package-lock.json && rm -rf /app/yarn.lock && yarn && if [ `$NODE_ENV` = `development` ]; then yarn run start; else yarn run build; fi"
logging:
options:
max-size: "10m"
max-file: "3"
networks:
- local_network
networks:
local_network:
Note that:
- When the
NODE_ENVis set todevelopment, it will run theyarn run startcommand. - yarn will try to recompile dependencies whenever there’s a react component change
mango-builderwill be built first before themango - The
buildfolder was generated bymango-builder, then it’s attached intomango(check thevolumessection) - The react app is running well at browser
When I try to change the react modules, somehow the hot reloading is not working.
I have a feeling I need to make the yarn run start keep running in the background, but I don’t know how to do it.
Any thoughts?
