I’ve created a custom resolver function to query & convert type of some DB collection attributes (e.g. timestamp stored originally as string type (“2021-08-11T10:29:52.000Z”) to GraphQL timestamp data type).
The function (below) has Resolver Field Name ‘TXN_AccountsWithDateTime’ and executes successfully return tXN_Accounts collection with the 4 date converted
const cluster = context.services.get("db-cluster") ;
const tXN_Accounts = cluster.db("DB").collection("TXN_Account") ;
const tXN_AccountsWithDateTime = await tXN_Accounts.aggregate( [
{ $set : { 'transactionDate' : { $toDate : '$transactionDate' } } },
{ $set : { 'transactionEffectiveDate' : { $toDate : '$transactionEffectiveDate' } } },
{ $set : { 'transactionObject.dateTime' : { $toDate : '$transactionObject.dateTime' } } },
{ $set : { 'balanceObject.dateTime' : { $toDate : '$balanceObject.dateTime' } } }
return tXN_AccountsWithDateTime;
As for Custom Resolver, I’ve defined the custom output type of ‘tXN_AccountsWithDatetime’ which is array of tXN_Account account collection, i.e.
"title": "TXN_AccountsWithDateTime",
"type": "array",
"items": {
"type": "object",
"properties": {
"_class": {
"bsonType": "string"
"_id": {
"accountId": {
"bsonType": "object",
On execute the query in GraphQL Explorer
query getAccountsWithDateTime {
TXN_AccountsWithDateTime {
returns the following error (though I’ve already defined the return type to be array as mentioned above)
"data": {
"TXN_AccountsWithDateTime": null
"errors": [
"message": "expected function call to have a scalar result, not a stream",
"locations": [
"line": 2,
"column": 3
"path": [
Appreciate any advice.
