Hi guys, I’m trying to create an existing query built in mongoose but using just aggregate pipeline, my current query using populate looks similar to this:
model
.find({ deleted: false, movie_id: id })
.populate('movie_id')
.populate('character_id');
Hello @PedroFumero , Welcome to the MongoDB community developer forum,
Yes almost correct, is there any error or are you asking to just check if we can do it other way as well?
I would suggest you can use $addFields and $arrayElemAt operators to get the first element from an array, instead of $unwind stage
$arrayElemAt to get specific position’s element from an array so we have selected the first element from the result of the lookup
You can also use a similar operator $first to get the first element from an array, just make sure for MongoDB support version
Thanks a lot! I have a question, in terms of performance is it better to apply $arrayElemAt instead of unwind? I’m looking to improve performance of original query, and btw using pipeline it performs better, but is even better $arrayElemAt instead of $unwind?, thanks in advance.
Not sure but not much difference if it is limited to a single element, But yes I can say number of more stages impacts the performance, here we have improved the query by eliminating the extra $unwnid stage, and we have covered both the operations in the single stage $addFields.
You can check explain() function to check the performance of the query.
