Connector with Power BI
I am using the Mongo Connector in Power BI, and everything is working fine. However, I discovered from reading some old posts that if we use the connector, it is not possible to schedule automatic updates in Power BI; we are dependent on the local Gateway.
Has any solution or update emerged so that, using the Mongo connector in Power BI, I do not depend on the Local Gateway and can configure automatic updates?
