I am new to MongoDB so I use the Atlas free tier to build a simple project. I built a simple java program (using java 8 and mongo-java-driver version 3.11.2) :
This works fine in a main function but when I try to put it in a web service and call it I get the following exception:
com.mongodb.MongoSocketWriteException: Exception sending message
at com.mongodb.internal.connection.InternalStreamConnection.translateWriteException(InternalStreamConnection.java:551)
at com.mongodb.internal.connection.InternalStreamConnection.sendMessage(InternalStreamConnection.java:433)
at com.mongodb.internal.connection.InternalStreamConnection.sendCommandMessage(InternalStreamConnection.java:273)
at com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:257)
at com.mongodb.internal.connection.CommandHelper.sendAndReceive(CommandHelper.java:83)
at com.mongodb.internal.connection.CommandHelper.executeCommand(CommandHelper.java:33)
at com.mongodb.internal.connection.InternalStreamConnectionInitializer.initializeConnectionDescription(InternalStreamConnectionInitializer.java:105)
at com.mongodb.internal.connection.InternalStreamConnectionInitializer.initialize(InternalStreamConnectionInitializer.java:62)
at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:129)
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:117)
at java.lang.Thread.run(Thread.java:748)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1688)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1038)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:966)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:750)
at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:123)
at com.mongodb.internal.connection.SocketStream.write(SocketStream.java:99)
at com.mongodb.internal.connection.InternalStreamConnection.sendMessage(InternalStreamConnection.java:430)
... 9 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302)
at sun.security.validator.Validator.validate(Validator.java:262)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1670)
... 18 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392)
... 24 more
thank you for your help! So I upgraded to jdk 8u271 and removed any previous jdks. The exception didn’t happen again, but now there is a new one:
com.mongodb.MongoException: java.lang.NoClassDefFoundError: Could not initialize class sun.security.ssl.SSLExtension
at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:138)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class sun.security.ssl.SSLExtension
at sun.security.ssl.SSLConfiguration.getEnabledExtensions(SSLConfiguration.java:380)
at sun.security.ssl.ClientHello$ClientHelloKickstartProducer.produce(ClientHello.java:562)
at sun.security.ssl.SSLHandshake.kickstart(SSLHandshake.java:509)
at sun.security.ssl.ClientHandshakeContext.kickstart(ClientHandshakeContext.java:110)
at sun.security.ssl.TransportContext.kickstart(TransportContext.java:233)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:394)
at sun.security.ssl.SSLSocketImpl.ensureNegotiated(SSLSocketImpl.java:808)
at sun.security.ssl.SSLSocketImpl.access$200(SSLSocketImpl.java:75)
at sun.security.ssl.SSLSocketImpl$AppOutputStream.write(SSLSocketImpl.java:1093)
... 2 more
com.mongodb.MongoException: java.lang.NoClassDefFoundError: sun/security/ssl/HelloExtension
Caused by: java.lang.NoClassDefFoundError: sun/security/ssl/HelloExtension
at sun.security.ssl.SSLExtension.<clinit>(SSLExtension.java:225)
I run my test using glassfish 5.0.1 through netbeans 12.1
