I’m unable to connect to host. The GUI is asking for a connection string (SRV OR STANDARD). Please provide the connection string.
Hi @Deepika_15237,
Please paste this connection string in the SRV OR Standard text field for connecting to the class atlas cluster.
mongodb://m001-student:m001-mongodb-basics@cluster0-shard-00-00-jxeqq.mongodb.net:27017/?authSource=admin&replicaSet=Cluster0-shard-0&readPreference=primaryPreferred&appname=MongoDB%20Compass&ssl=true
Alternatively you can also fill in the individual fields. Please click on Fill in connection fields individually and follow the instructions mentioned in the Lecture : Connecting to MongoDB Using Compass.
Hope it helps!
If you have any other query then please feel free to get back to us.
Shubham Ranjan
Curriculum Support Engineer
Hello,
I am trying to connect to compass using the values described in the course ware and I am getting this error
connect ECONNREFUSED 52.4.238.74:27017
I have uploaded the screenshot of the screen. Pls advise
Swatee
It looks like you might be behind a corporate firewall or VPN that prevents outbound connection.
Check with you system admin.
Hi @Swatee_Jain,
In addition to @steevej-1495,
Did you try to use connection string as well ? it’s better and efficient.
mongodb+srv://m001-student:m001-mongodb-basics@cluster0-jxeqq.mongodb.net/test
~ Shubham
Thank you for your suggestions. As suggested it is due to corporate firewall. I also tried connection string with same error. I was able to connect on my home laptop.
Swatee
