MongoDB server 5.0.1
PyMongo 3.12.0
Zstd compression level setting is declared in MongoDB 5.0. But it doesn’t work for me in PyMongo.
Code:
coll_obj = trg_db_obj.create_collection(src_file_name[:-3], storageEngine={'wiredTiger': {'configString': 'block_compressor=zstd,zstdCompressionLevel=22'}})
Error:
pymongo.errors.OperationFailure: 22: Invalid argument. [1627214735:927020][2228:0x7fce9f9c1700], wiredtiger_config_validate: config_check_search, 65: unknown configuration key: 'zstdCompressionLevel': Invalid argument., full error: {'ok': 0.0, 'errmsg': "22: Invalid argument. [1627214735:927020][2228:0x7fce9f9c1700], wiredtiger_config_validate: config_check_search, 65: unknown configuration key: 'zstdCompressionLevel': Invalid argument.", 'code': 2, 'codeName': 'BadValue'}
If I replace zstdCompressionLevel
to zstd_compression_level
, the result is the same.
I believe those options are only configurable by way of MongoDB’s configuration file, not through the createCollection command.
Okay, let that be my feature request.
Currently facing the same problem, it would be very beneficial if the compression level could be set on a collection level.
Stennie_X
(Stennie)
October 11, 2021, 11:33pm
6
Hi @Robin_Muller , @Platon_workaccount ,
For server feature requests, please create a new suggestion on the MongoDB Feedback site including more information on your use case.
As noted earlier in this discussion, zstdCompressionLevel
is a server-level configuration setting added in MongoDB 5.0. If you are using zstd
as a blockCompressor
and change the zstdCompressionLevel
value, all subsequent collections created will inherit this default.
Stennie
system
(system)
Closed
October 17, 2021, 7:01am
7
