There is an ETA for Client-Side Field Level Encryption for Linux in C# Drivers? I need it! Thanks
Hi @Giorgio_Tresoldi, and welcome to the forum,
This should work with MongoDB .NET/C# driver that is compatible with v4.2 (version 2.10+). See github.com/mongodb-labs/field-level-encryption-sandbox/c-sharp for an example code.
See also Client Side Field Level Encryption Guide.
If you’re encountering an issue trying to perform CSFLE in Linux, could you provide:
- MongoDB .NET/C# driver version
- MongoDB server version
- Any relevant code snippets
- Any error messages that you’re encountering
Wan.
Here https://mongodb.github.io/mongo-csharp-driver/2.10/reference/driver/crud/client_side_encryption/ are specified that “Client-side field level encryption is supported only on Windows.” but my project works on linux docker containers.
Unfortunately you’re correct, although there is a work around there are some tasks that needed to be completed. This is currently scheduled to be worked on, please feel free to add yourself as a watcher or up-vote the issue tracker CSHARP-2715: FLE on Linux/Mac to receive notifications for progress on the ticket.
Wan.
@wan Are there any plans to release this functionality? When?
What is the contour output currently?
My application works on Linux Container also.
