Hi there. My objective is to run our application in Github codespaces. This works great, but I can’t connect to the Mongodb instance, from my local machine with for example MongoDB Compass.
docker-compose.yml
version: '3.8'
services:
app:
build:
context: .
dockerfile: Dockerfile
args:
# Update 'VARIANT' to pick an LTS version of Node.js: 16, 14, 12.
# Append -bullseye or -buster to pin to an OS version.
# Use -bullseye variants on local arm64/Apple Silicon.
VARIANT: '16'
volumes:
- ..:/workspace:cached
init: true
environment:
EDDY_CLI_KEY_PATH: /workspace
# Overrides default command so things don't shut down after the process ends.
command: sleep infinity
# Runs app on the same network as the database container, allows "forwardPorts" in devcontainer.json function.
network_mode: service:db
# Uncomment the next line to use a non-root user for all processes.
# user: node
# Use "forwardPorts" in **devcontainer.json** to forward an app port locally.
# (Adding the "ports" property to this file will not forward from a Codespace.)
# mongosetup:
# image: mongo:latest
# depends_on:
# - db
# restart: 'no'
# entrypoint: ['bash', '-c', "sleep 10 && mongo --host localhost:27017 --eval 'rs.initiate()'"]
db:
# Based on https://stackoverflow.com/q/67020325/3694288
image: mongo:5
restart: unless-stopped
# deploy:
# replicas: 1
volumes:
- mongodb-data:/data/db
- ./mongo-scripts:/docker-entrypoint-initdb.d/
- type: bind
source: ./mongod.conf
target: /etc/mongod.conf
# entrypoint: ['mongod', '--config', '/etc/mongod.conf']
# command: ['--replSet', 'rs0', '--bind_ip_all']
command: '--bind_ip_all --replSet rs0'
# Uncomment to change startup options
# environment:
# - PUID=1000
# - PGID=1000
# - MONGO_INITDB_ROOT_USERNAME=mongo
# - MONGO_INITDB_ROOT_PASSWORD=mongo
# - MONGO_INITDB_DATABASE=my-service
# - MONGO_REPLICA_SET_NAME=rs0
ports:
- 27017:27017
# healthcheck:
# test: test $$(echo "rs.initiate().ok || rs.status().ok" | mongo -u $${MONGO_INITDB_ROOT_USERNAME} -p $${MONGO_INITDB_ROOT_PASSWORD} --quiet) -eq 1
# interval: 10s
# start_period: 30s
# Add "forwardPorts": ["27017"] to **devcontainer.json** to forward MongoDB locally.
volumes:
mongodb-data: null
devcontainer.json
// For format details, see https://aka.ms/devcontainer.json. For config options, see the README at:
// https://github.com/microsoft/vscode-dev-containers/tree/v0.203.0/containers/javascript-node-mongo
// Update the VARIANT arg in docker-compose.yml to pick a Node.js version
"name": "Node.js & Mongo DB",
"dockerComposeFile": "docker-compose.yml",
"service": "app",
"workspaceFolder": "/workspace",
// Set *default* container specific settings.json values on container create.
"settings": {},
// Add the IDs of extensions you want installed when the container is created.
"extensions": [
"vscode-icons-team.vscode-icons",
"esbenp.prettier-vscode",
"hediet.vscode-drawio",
"bradlc.vscode-tailwindcss",
"svelte.svelte-vscode",
"dbaeumer.vscode-eslint"
// Use 'forwardPorts' to make a list of ports inside the container available locally.
"forwardPorts": [3000, 27017],
// Use 'postCreateCommand' to run commands after the container is created.
"postCreateCommand": "npm ci && npm run build:cli && npm link",
"portsAttributes": {
"3000": {
"label": "Svelte (front-end)",
"onAutoForward": "notify",
"protocol": "http"
// Comment out connect as root instead. More info: https://aka.ms/vscode-remote/containers/non-root.
"remoteUser": "node",
"features": {
"git": "os-provided"
The app itself can connect to the Mongodb instance, without issues. Port forwarding is made public like here:
However when I try to connect from MongoDB Compass running locally with:
mongodb://<code-space-name>-4q75x555hj7rv-27017.githubpreview.dev:80
I always get:
or
Would be so thankful for any points in the right direction ![]()
