Hello there, I am trying to evaluate whether I can create a Mongo view which joins two collections and inspects two arrays of Guids. Ideally, I would like to use a view, since I have a C# API layer which is leveraging IQueryable and expressions through the MongoDB C# driver. If need be, I could also probably use the aggregation pipeline and aggregate().
In a nutshell here is an example of the two collections:
FirstCollection: (probably can have 500,000-600,000 documents max or so)
"_id": "2010-0001"
"ArrayOfGuids": [ Guid1, Guid2, Guid8]
..other fields not important
"_id": "2010-0002"
"ArrayOfGuids": [ Guid7, Guid10, Guid5]
"_id": "2010-0003"
"ArrayOfGuids": [ Guid14, Guid11, Guid3]
SecondCollection: (probably will not contain more then 1000 documents)
"_id": "SomeId",
"name": "SomeName"
"modified": DateTime
"ArrayOfGuids": [ Guid1, Guid2, Guid3]
The “intersection” I need to do is between the 2 collections on the “ArrayOfGuids” properties. For every document in the SecondCollection, if the ArrayOfGuids has any match in FirstCollection, return a projection of:
SecondCollection._id,
SecondCollection.name,
SecondCollection.modified,
FirstCollection._id (as array)
From the data sample above, one projection returned would be
"_id": "SomeId",
"name": "SomeName"
"mappedOtherIds": ["2010-0001","2010-0003"]
So, since FirstCollection _id “2010-0001” and _id “2010-0003” contain a matching Guid in its corresponding array, it is included in the result. The smaller collection is more or less the primary data to return, but I need to project the array of ids from the FirstCollection where an array item match exists.
The larger FirstCollection does have an index on the “ArrayOfGuids” field and its _id field. Unfortunately, the smaller, second collection does not have an index on the “ArrayOfGuids” column, but the addition of another index is potentially possible.
I have looked and $unwind and flattening both arrays but that didn’t seem to lead me to a proper intersection query. I am also looking to create a view which is as optimal as possible, given I don’t want to revert to doing this in memory at the app tier and using auxiliary caches and such. If this query would be too intensive and slow, I probably have to abandon the idea. Also, restructuring these collections, minus adding an index or so, is not possible at the moment.
If anyone can provide a sample or advice to nudge me in the right direction, that would be great. Thanks in advance.
