As part of our project implementation, we are using Counters to auto increment certain fields of the collection as needed. We are using C# as programming language and using Mongo DB Native Drivers to connect to Mongo DB.
If I am using Mongo DB Command in Mongo Shell to insert a document which uses a function to auto increment a value, we run the below command. Here, you can see that we are calling the function.
db.student.insert({
studentnum: getSequenceNextValue("studentnum"),
student_id: "02940409",
course: "Bachelor of Science in Computer Engineering",
year_level: "2nd",
department: "engineering"
getNextSequenceValue is a function which gives me the next counter value for use. But C# does not accept use of the function, instead, it expects a value.
var document = new BsonDocument { { “studentnum”, getSequenceNextValue(“studentnum”), }};
Is there a way in C# using Mongo DB Driver to achieve this? Or is there a way to run native Mongo DB Shell commands from C#?
Unfortunately, it does not work that way. I have already looked at this post and tried it. It works for commands where there is no function involved. For example, if I try either of the below, it does not work and expects a JSON:
var stringCommand = "{\"_id\": getSequenceNextValue(\"itemId\"),\"student_id\": \"02740305\",\"course\": \"Bachelor of Science in Finance\",\"year_level\": \"2nd\",\"department\": \"Business Administration\"}";
var command = new JsonCommand<BsonDocument>(stringCommand);
database.RunCommand(command);
var stringCommand = "db.student.insert({\"_id\": getSequenceNextValue(\"itemId\"),\"student_id\": \"02740305\",\"course\": \"Bachelor of Science in Finance\",\"year_level\": \"2nd\",\"department\": \"Business Administration\"});";
So, that Run Command does not run native Mongo Shell commands unfortunately.
