Hello,
I’ve read both https://docs.atlas.mongodb.com/reference/unsupported-commands/ and https://docs.atlas.mongodb.com/reference/free-shared-limitations/ as well as https://docs.mongodb.com/manual/reference/operator/aggregation/or/index.html and https://docs.mongodb.com/manual/reference/operator/query/or/index.html but I cannot understand why I’m given AtlasError below when there’s nowhere to be found that $or
is limited/unsupported.
"ok": 0,
"errmsg": "$or is not allowed in this atlas tier",
"code": 8000,
"codeName": "AtlasError",
"name": "MongoError"
Can anyone give me some insight as to why is that, when documentation doesn’t state that the operator is limited/unsupported?
Thank you
steevej
(Steeve Juneau)
May 3, 2020, 10:16pm
#2
You do not provide enough context to understand your issue. What command or action were you doing when you got this error.
Inside an aggregate, one of the steps I added was $match with an $or inside.
Stennie
(Stennie)
May 3, 2020, 11:06pm
#4
Hi Raphael,
Can you provide an example of the aggregation pipeline you are executing and confirm the Atlas tier you are using?
Stennie
I first tried with:
coll.find({$or: [{_id: _id},{id: _id }]})
And I got the error. Then I tried on aggregate
coll.aggregate([
$match: {
$or: [{ _id: _id }, { id: _id }, { name: _id }],
And I got same error as well.
But oddly enough, I ran today again the aggregate just to make sure before replying and did not give me the error I posted on the first post, instead, it worked.
I’m using M0 Free Plan.
Maybe it had an issue on my end, I don’t know. O.o
