Hello
I am using mongo realm for my Android Studio application. When using .updateOne method to update a Document inside one of my “users” Collection, I use this code:
Bson filter = Filters.eq("_id", userid);
Bson update = Updates.combine(
Updates.inc("numberToIncrement", 1),
Updates.push("animalArray", "fish")
usersCollection.updateOne(filter , update).getAsync(task -> { ...
In Android Studio it shows me no errors, but when I try to run the code, the error for “Filters” comes:
BSON_CODEC_NOT_FOUND(realm::app::CustomError:1100): Could not resolve codec for SimpleEncodingFilter
org.bson.codecs.configuration.CodecConfigurationException: Can't find a codec for CodecCacheKey{clazz=class com.mongodb.client.model.Filters$SimpleEncodingFilter, types=null}.
at org.bson.internal.ProvidersCodecRegistry.lambda$get$0$org-bson-internal-ProvidersCodecRegistry(ProvidersCodecRegistry.java:87)
and a similar error emerges for the “Updates”-part when I replace “Bson filter = Filters.eq(”_id", userid);" with “Document filter = new Document(”_id", userid);":
BSON_CODEC_NOT_FOUND(realm::app::CustomError:1100): Could not resolve codec for CompositeUpdate
org.bson.codecs.configuration.CodecConfigurationException: Can't find a codec for CodecCacheKey{clazz=class com.mongodb.client.model.Updates$CompositeUpdate, types=null}.
My specs:
Android Gradle Plugin Version 8.1.2 . Gradle Version 8.4 . Compile SDK Version 34. Java Version 17. For implementation I use in my build.gradle: implementation ‘org.mongodb:mongodb-driver-sync:4.10.2’
Additional information:
Before getting this error, I had to include in my build.gradle:
packagingOptions {
exclude 'META-INF/native-image/org.mongodb/bson/native-image.properties'
because I got the error:
Execution failed for task ':app:mergeDebugJavaResource'.
> A failure occurred while executing com.android.build.gradle.internal.tasks.MergeJavaResWorkAction
> 2 files found with path 'META-INF/native-image/org.mongodb/bson/native-image.properties' from inputs:
- E:\.gradle\caches\transforms-3\a6834347cc909f58f15e170b45aed9c5\transformed\jetified-mongodb-driver-core-4.11.0.jar
- E:\.gradle\caches\transforms-3\7887ee97f50a4509db80ce209ca44106\transformed\jetified-bson-4.11.0.jar
Adding a packagingOptions block may help, please refer to
https://developer.android.com/reference/tools/gradle-api/8.1/com/android/build/api/dsl/ResourcesPackagingOptions
for more information
Can anyone help me in this ??? I am desperate and haven’t found helpful info about this affair yet.
Best regards and thanks in advance <3
