I am quite sure the behavior has changed between 5.0.5 and 5.0.23 because we were seeing different behavior in development and production, which were running different versions.
If it is unsupported behavior, we will probably just stop using sparse indexes in $lookup related contexts.
For testing purposes, I have added the explain values on both versions.
Below you can find the results in which you can see, one uses the index, the other does not.
let: { presentationId: "$_id" },
pipeline: [
$match: {
$expr: {
$eq: [
"$presentationId",
"$$presentationId",
as: "assignments",
with sparse index present on presentationId: 1 for the assignments collection.
5.0.5
"explainVersion": "1",
"stages": [
"$cursor": {
"queryPlanner": {
"namespace": "meteor.presentations",
"indexFilterSet": false,
"parsedQuery": {},
"queryHash": "8B3D4AB8",
"planCacheKey": "D542626C",
"maxIndexedOrSolutionsReached": false,
"maxIndexedAndSolutionsReached": false,
"maxScansToExplodeReached": false,
"winningPlan": {
"stage": "COLLSCAN",
"direction": "forward"
"rejectedPlans": []
"executionStats": {
"executionSuccess": true,
"nReturned": 11,
"executionTimeMillis": 1,
"totalKeysExamined": 0,
"totalDocsExamined": 11,
"executionStages": {
"nReturned": 11,
"executionTimeMillisEstimate": 0,
"works": 13,
"advanced": 11,
"needTime": 1,
"needYield": 0,
"saveState": 1,
"restoreState": 1,
"isEOF": 1,
"direction": "forward",
"docsExamined": 11
"allPlansExecution": []
"nReturned": 11,
"$lookup": {
"from": "assignments",
"as": "assignments",
"let": {
"presentationId": "$_id"
"pipeline": [
"$match": {
"$expr": {
"$eq": [
"$presentationId",
"$$presentationId"
"totalDocsExamined": 3,
"totalKeysExamined": 3,
"collectionScans": 0,
"indexesUsed": [
"presentationId_1"
"nReturned": 11,
"executionTimeMillisEstimate": 1
"serverInfo": {
"host": "mongodb",
"port": 27017,
"version": "5.0.5",
"gitVersion": "d65fd89df3fc039b5c55933c0f71d647a54510ae"
"serverParameters": {
"internalQueryFacetBufferSizeBytes": 104857600,
"internalQueryFacetMaxOutputDocSizeBytes": 104857600,
"internalLookupStageIntermediateDocumentMaxSizeBytes": 104857600,
"internalDocumentSourceGroupMaxMemoryBytes": 104857600,
"internalQueryMaxBlockingSortMemoryUsageBytes": 104857600,
"internalQueryProhibitBlockingMergeOnMongoS": 0,
"internalQueryMaxAddToSetBytes": 104857600,
"internalDocumentSourceSetWindowFieldsMaxMemoryBytes": 104857600
"command": {
"aggregate": "presentations",
"pipeline": [
"$lookup": {
"let": {
"pipeline": [
"$match": {
"$expr": {
"$eq": [
"$presentationId",
"$$presentationId"
"as": "assignments"
"allowDiskUse": true,
"cursor": {},
"maxTimeMS": 60000,
"$db": "meteor"
"ok": 1,
"$clusterTime": {
"clusterTime": {
"$timestamp": {
"t": 1704307112,
"i": 1
"signature": {
"hash": {
"$binary": {
"base64": "AAAAAAAAAAAAAAAAAAAAAAAAAAA=",
"subType": "00"
"keyId": 0
"operationTime": {
"$timestamp": {
"t": 1704307112,
"i": 1
5.0.23
"stages": [
"$cursor": {
"queryPlanner": {
"parsedQuery": {},
"winningPlan": {
"rejectedPlans": []
"executionStats": {
"nReturned": 11,
"nReturned": 11,
"works": 13,
"advanced": 11,
"needTime": 1,
"needYield": 0,
"saveState": 1,
"restoreState": 1,
"isEOF": 1,
"docsExamined": 11
"nReturned": 11,
"$lookup": {
"let": {
"pipeline": [
"$match": {
"$expr": {
"$eq": [
"$presentationId",
"$$presentationId"
"totalDocsExamined": 55,
"collectionScans": 22,
"indexesUsed": [],
"nReturned": 11,
"serverInfo": {
"host": "mongodb",
"port": 27017,
"version": "5.0.23",
"gitVersion": "3367195a14d0ba2734d2ba2719294fb974ad0834"
"command": {
"pipeline": [
"$lookup": {
"let": {
"pipeline": [
"$match": {
"$expr": {
"$eq": [
"$presentationId",
"$$presentationId"
"as": "assignments"
"cursor": {},
"maxTimeMS": 60000,
"$db": "meteor"
"ok": 1,
"$clusterTime": {
"clusterTime": {
"$timestamp": {
"t": 1704307205,
"i": 1
"signature": {
"hash": {
"$binary": {
"subType": "00"
"keyId": 0
"operationTime": {
"$timestamp": {
"t": 1704307205,
"i": 1
