I tried running below command from mongo shell. but i’m getting error as “2020-04-02T21:46:25.488+0530 E QUERY [js] uncaught exception: SyntaxError: unexpected token: string literal :”
mongo “mongodb+srv://cluster0-jxeqq.mongodb.net/test” --username m001-student -password m001-mongodb-basics
The string is fine.I can connect
By any chance are you at mongo prompt?
Please exit and run the command again from your os prompt
Hi @ramya29p,
As @Ramachandra_37567 mentioned, most likely you are already inside the mongo shell. Please use the exit
command to exit out of the mongo shell.
Hope it helps!
Please feel free to get back to us if you have any other query.
~ Shubham
Thank you. It worked.
