I’m running a function trying to obtain a token from twilio. Everything goes well until I call the method token.toJwt()
at that point I get the following error {"message":"Value is not an object: undefined","name":"TypeError"}
Running exactly the same function in my local node works perfectly so I don’t understand what is causing the method to fail. I double checked that all env variables are correct. Any ideas will be greatly appreciated.
The code is basically the same as in Twilio docs: Create Access Tokens for Conversations | Twilio
exports = async function() {
// Documentation: https://www.twilio.com/docs/conversations/create-tokens
const twilio = require('twilio');
const AccessToken = twilio.jwt.AccessToken;
const ChatGrant = AccessToken.ChatGrant;
// Twilio tokens and keys
const twilioAccountSid = context.values.get("TWILIO_ACCOUNT_SID_VALUE");
const twilioApiKey = context.values.get("TWILIO_API_KEY_VALUE");
const twilioApiSecret = context.values.get("TWILIO_API_SECRET_VALUE");
// Used specifically for creating Chat tokens
const serviceSid = context.values.get("TWILIO_CHAT_SERVICE_SID_VALUE");
// Only application users can request a chat token
// This can be changed if other services need a token
if (context.user.type !== "normal") {
return { error: "Error: Not an application user." }
try {
// Create a "grant" which enables a client to use Chat as a given user, on a given device
const chatGrant = new ChatGrant({
serviceSid: serviceSid,
// Create an access token which we will sign and return to the client,
// containing the grant we just created
const token = new AccessToken(
twilioAccountSid,
twilioApiKey,
twilioApiSecret,
{ identity: context.user.data.email }
token.addGrant(chatGrant);
return { token: token.toJwt() };
} catch (err) {
console.log(err.stack);
console.log("Error occurred while getting a chat token:", err.message);
return { error: err };
