Trouble with pytest -m connection
I was following #M220P course and all went well until I had to “pytest” it.
I’m using a Ubuntu 18.04 server in AWS to do that.
I was succesful in connecting my browser to the page mflix generated by run.py. (so I clearly can connect to Atlas DB)
This is what I’m seeing when “pytest -m connection” is isued
Error Message
================================================================================= test session starts =================================================================================
platform linux – Python 3.6.8, pytest-3.3.0, py-1.8.0, pluggy-0.6.0
rootdir: /python/M220P, inifile:
plugins: flask-0.10.0
collected 0 items / 1 errors
======================================================================================= ERRORS ========================================================================================
__________________________________________________________________________________ ERROR collecting __________________________________________________________________________________
lib/python3.6/site-packages/_pytest/config.py:327: in _getconftestmodules
return self._path2confmods[path]
E KeyError: local(’/python/M220P/lib/python3.6/site-packages/notebook/tests/selenium’)
During handling of the above exception, another exception occurred:
lib/python3.6/site-packages/_pytest/config.py:358: in _importconftest
return self._conftestpath2mod[conftestpath]
E KeyError: local(’/python/M220P/lib/python3.6/site-packages/notebook/tests/selenium/conftest.py’)
lib/python3.6/site-packages/_pytest/config.py:364: in _importconftest
mod = conftestpath.pyimport()
lib/python3.6/site-packages/py/_path/local.py:701: in pyimport
import(modname)
lib/python3.6/site-packages/pytest/assertion/rewrite.py:212: in load_module
py.builtin.exec
(co, mod.dict)
lib/python3.6/site-packages/notebook/tests/selenium/conftest.py:4: in
import requests
E ModuleNotFoundError: No module named ‘requests’
lib/python3.6/site-packages/py/_path/common.py:377: in visit
for x in Visitor(fil, rec, ignore, bf, sort).gen(self):
lib/python3.6/site-packages/py/_path/common.py:429: in gen
for p in self.gen(subdir):
lib/python3.6/site-packages/py/_path/common.py:418: in gen
dirs = self.optsort([p for p in entries
lib/python3.6/site-packages/py/_path/common.py:419: in
if p.check(dir=1) and (rec is None or rec§)])
lib/python3.6/site-packages/_pytest/main.py:723: in _recurse
ihook = self.gethookproxy(path)
lib/python3.6/site-packages/_pytest/main.py:627: in gethookproxy
my_conftestmodules = pm._getconftestmodules(fspath)
lib/python3.6/site-packages/_pytest/config.py:341: in _getconftestmodules
mod = self._importconftest(conftestpath)
lib/python3.6/site-packages/_pytest/config.py:366: in _importconftest
raise ConftestImportFailure(conftestpath, sys.exc_info())
E _pytest.config.ConftestImportFailure: ModuleNotFoundError(“No module named ‘requests’”,)
E File "/python/M220P/lib/python3.6/site-packages/pytest/assertion/rewrite.py", line 212, in load_module
E py.builtin.exec
(co, mod.dict)
E File “/python/M220P/lib/python3.6/site-packages/notebook/tests/selenium/conftest.py”, line 4, in
E import requests
!!! Interrupted: 1 errors during collection !!!
=============================================================================== 1 error in 3.18 seconds ===============================================================================
What should I do to pass the lab?
I think the requests Python-Module is not installed.
Try running pip3 install requests command on your EC2 instance command line terminal.
Please reply if it helped.
It was installed.
But never mind, I’m able to do the LABs without it :wink:
Hello @fenetto I have same issue how did that error message rectified can you tell me
