An error occurred while loading navigation: connection 7 to cluster0-shard-00-01-jxeqq.mongodb.net:27017 timed out
Getting above error while trying to connect to cluster. Also it is taking long time for schema analysis and results obtained is time out.
My OS is windows 8.1 , 64 bit. I am having good browsing speed so my network connectivity is also not an issue. No restricted firewall.
Please help me with solution. Thank you in advance.
Mostly it is internet related speed or try another browser
For some students using lower version worked
What version are you using?Use latest stable version
Please check our forum.Many threads available
Hi @Chanchal_51561,
This is a publicly available cluster and it is up and running. I believe the issue that you are facing is local to your network/system.
Can you please try to connect using some other network ?
Please let me know if the issue still persists.
Shubham Ranjan
Curriculum Support Engineer
