I created a custom Id type that wraps an integer. I implemented the equality operators for this type. The problem is, when I want to filter in mongoDB with linq and the expression includes this custom operator, the expression translator throws an error.
Code:
using MongoDB.Bson.Serialization;
using MongoDB.Bson.Serialization.Attributes;
using MongoDB.Bson.Serialization.Serializers;
using MongoDB.Driver;
int idToFind = 5;
var filter = Builders<MyDocument>.Filter.Where(x => x.Id == idToFind);
var renderedFilter = filter.Render(BsonSerializer.LookupSerializer<MyDocument>(), BsonSerializer.SerializerRegistry);
Console.WriteLine(renderedFilter);
public class MyDocument
public MyId Id { get; set; }
public string Name { get; set; }
[BsonSerializer(typeof(MyIdSerializer))]
public class MyId
public MyId(int id)
Id = id;
public int Id { get; }
public static bool operator ==(int id, MyId other) => id == other.Id;
public static bool operator ==(MyId id, int other) => id.Id == other;
public static bool operator !=(int id, MyId other) => !(id == other);
public static bool operator !=(MyId id, int other) => !(id == other);
public class MyIdSerializer : SerializerBase<MyId>
public override MyId Deserialize(BsonDeserializationContext context, BsonDeserializationArgs args)
return new MyId(context.Reader.ReadInt32());
public override void Serialize(BsonSerializationContext context, BsonSerializationArgs args, MyId value)
context.Writer.WriteInt32(value.Id);
Exception:
Unhandled exception. System.InvalidCastException: Unable to cast object of type 'System.Int32' to type 'MyId'.
at MongoDB.Bson.Serialization.Serializers.SerializerBase`1.MongoDB.Bson.Serialization.IBsonSerializer.Serialize(BsonSerializationContext context, BsonSerializationArgs args, Object value)
at MongoDB.Bson.Serialization.IBsonSerializerExtensions.Serialize(IBsonSerializer serializer, BsonSerializationContext context, Object value)
at MongoDB.Driver.Linq.Linq3Implementation.Misc.SerializationHelper.SerializeValue(IBsonSerializer serializer, Object value)
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToFilterTranslators.ExpressionTranslators.ComparisonExpressionToFilterTranslator.Translate(TranslationContext context, BinaryExpression expression)
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToFilterTranslators.ExpressionToFilterTranslator.TranslateUsingQueryOperators(TranslationContext context, Expression expression)
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToFilterTranslators.ExpressionToFilterTranslator.Translate(TranslationContext context, Expression expression, Boolean exprOk)
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToFilterTranslators.ExpressionToFilterTranslator.TranslateLambda(TranslationContext context, LambdaExpression lambdaExpression, IBsonSerializer parameterSerializer, Boolean asRoot)
at MongoDB.Driver.Linq.Linq3Implementation.LinqProviderAdapterV3.TranslateExpressionToFilter[TDocument](Expression`1 expression, IBsonSerializer`1 documentSerializer, IBsonSerializerRegistry serializerRegistry)
at MongoDB.Driver.ExpressionFilterDefinition`1.Render(IBsonSerializer`1 documentSerializer, IBsonSerializerRegistry serializerRegistry, LinqProvider linqProvider)
at MongoDB.Driver.FilterDefinition`1.Render(IBsonSerializer`1 documentSerializer, IBsonSerializerRegistry serializerRegistry)
at Program.<Main>$(String[] args) in C:\src\MongoTest\MongoTest\Program.cs:line 9
