Sync Permission problem
I have modified the task application and have a Realm Sync in Development Mode. Yet it continues to give me this error and doesn’t create the new objects in the back end. Doesn’t seem to sync any in the back end.
Ending session with error: user cannot perform additive schema changes without write access: additive schema change: adding schema for Realm table “Client”, additive changes from clients are restricted when developer mode is disabled (ProtocolErrorCode=206)
Am I missing another switch?
Hi @James_Cicenia I’d suggest terminating sync and then re-enabling it. I’d also uninstall your app and then reinstall it. That way you should start from a known. clean state.
