Im using Java Realm SDK.
The app works fine when network connectivity is available. App even works when i turn off data connectivity after opening app.
But when i restart app with no data connectivity. It is unable to fetch the local data.
How to Reproduce:
Turn off data connectivity.
Open app
App unable to sync.
What I got after diagnosing:
After I restart the app without data connectivity. The app is unable to set SyncConfiguration as a result realm is not able to fetch any data.
Hence as Mongo says it is offline first I’m able to use this important feature.
But when I turn off data while running app. the app works fine. as SyncConfiguration is already set.
This is My sync configuration:
config = new SyncConfiguration.Builder(app.currentUser())
.allowWritesOnUiThread(true)
.allowQueriesOnUiThread(true)
.compactOnLaunch()
.waitForInitialRemoteData(500, TimeUnit.MILLISECONDS)
.initialSubscriptions(new SyncConfiguration.InitialFlexibleSyncSubscriptions() {
@Override
public void configure(Realm realm, MutableSubscriptionSet subscriptions) {
// add a subscription with a name
Log.e(TAG, "configure: ");
Subscription userSubscription = subscriptions.find(kMap.userSubs);
if (userSubscription == null) {
subscriptions.addOrUpdate(Subscription.create(kMap.userSubs,
realm.where(users.class)));
Subscription collegeSubscription = subscriptions.find(kMap.collegeSubs);
if (collegeSubscription == null) {
subscriptions.addOrUpdate(Subscription.create(kMap.collegeSubs,
realm.where(colleges.class)));
Subscription courseSubscription = subscriptions.find(kMap.courseSubs);
if (courseSubscription == null) {
subscriptions.addOrUpdate(Subscription.create(kMap.courseSubs,
realm.where(courses.class)));
Subscription studentsSubs = subscriptions.find(kMap.studentsSubs);
if (studentsSubs == null) {
subscriptions.addOrUpdate(Subscription.create(kMap.studentsSubs,
realm.where(students.class)));
realm.close();
.build();
Realm.setDefaultConfiguration(config);
StaticValues.syncCount++;
Error I get while internet is off:
E/REALM_JAVA: Session Error[wss://realm.mongodb.com/]: UNKNOWN(realm.util.network.resolve:1): Host not found (authoritative)
E/REALM_SYNC: Failed to resolve ‘ws.ap-south-1.aws.realm.mongodb.com:443’: Host not found (authoritative)
