Hi everybody,
I have a strange issue on my atlas realm app:
I have partition sync enabled and a view that runs several aggregation stages to combine data.
There are two mutually exclusive errors that are thrown:
when I define a schema for the view, I get TranslatorFatalError with the following message:
recoverable event subscription error encountered: failed to configure namespaces for sync: failed to configure namespace ns=‘sias.siteInfo’ for sync: error issuing collMod command for ns=‘sias.siteInfo’: (InvalidOptions) option not supported on a view: recordPreImages
when I remove the schema for the view, i get NoMatchingRuleFound with the following message:
Action on service ‘mongodb-atlas’ forbidden: arguments to ‘find’ don’t match rule criteria
"name": "find",
"arguments": [
"database": "sias",
"collection": "siteInfo",
"query": {}
"service": "mongodb-atlas"
Does someone encountered the same issue?
How can I disable recordPreImages for the view? (is not showed in “linked data source” advanced config options…)
thanks
