Hi @Nimisha - Welcome to the community.
Is it not possible to rank docs based on multiple fields?
Yes, currently using $rank
with multiple fields is not possible. There is currently a SERVER ticket raised for this behaviour - SERVER-56572. As noted on the ticket, a potential workaround is:
to prepend an $addFields
stage that places the compound set of fields into their own sub-object, then applying the window function rank on that new object.
I am not sure if this would work for your use case but I had created the following documents in my test environment:
DB>db.user_score.find()
{ _id: ObjectId("638433ca31f9fbfd0869f475"), score: 1, attempts: 1 },
{ _id: ObjectId("638433ce31f9fbfd0869f476"), score: 1, attempts: 2 },
{ _id: ObjectId("638433d031f9fbfd0869f477"), score: 1, attempts: 3 },
{ _id: ObjectId("638433d731f9fbfd0869f478"), score: 2, attempts: 1 },
{ _id: ObjectId("638433d931f9fbfd0869f479"), score: 2, attempts: 2 },
{ _id: ObjectId("638433da31f9fbfd0869f47a"), score: 2, attempts: 3 },
{ _id: ObjectId("638433de31f9fbfd0869f47b"), score: 3, attempts: 3 },
{ _id: ObjectId("638433df31f9fbfd0869f47c"), score: 3, attempts: 1 },
{ _id: ObjectId("638433e131f9fbfd0869f47d"), score: 3, attempts: 2 },
{ _id: ObjectId("638433e231f9fbfd0869f47e"), score: 3, attempts: 3 }
I then created added an extra field with the "score"
and "attempts"
values within it as an object before running the $setWindowFields
with $rank
db.user_score.aggregate([
'$addFields': { testField: { score: '$score', attempts: '$attempts' } }
'$setWindowFields': {
sortBy: { testField: -1 },
output: { scoreRank: { '$rank': {} } }
score: 3,
attempts: 3,
testField: { score: 3, attempts: 3 },
scoreRank: 1
score: 3,
attempts: 3,
scoreRank: 1
score: 3,
attempts: 2,
testField: { score: 3, attempts: 2 },
scoreRank: 3
score: 3,
attempts: 1,
testField: { score: 3, attempts: 1 },
scoreRank: 4
score: 2,
attempts: 3,
testField: { score: 2, attempts: 3 },
scoreRank: 5
score: 2,
attempts: 2,
testField: { score: 2, attempts: 2 },
scoreRank: 6
score: 2,
attempts: 1,
testField: { score: 2, attempts: 1 },
scoreRank: 7
score: 1,
attempts: 3,
testField: { score: 1, attempts: 3 },
scoreRank: 8
score: 1,
attempts: 2,
testField: { score: 1, attempts: 2 },
scoreRank: 9
score: 1,
attempts: 1,
testField: { score: 1, attempts: 1 },
scoreRank: 10
In the meantime, I have also created a request to have the documentation updated to perhaps note that only a single element in the sortBy
when using $rank
Jason
