I follow these instructions:
Use the following information to complete this form, but do not click “Connect” yet. Hostname is cluster0-shard-00-00-jxeqq.mongodb.net. Username is m001-student. Password is m001-mongodb-basics, when trying to connect it gives this message:
authentication fail
Check with this, if there is response from the server:
ping cluster0-shard-00-00-jxeqq.mongodb.net
This is your answer:
Pinging ec2-34-195-121-130.compute-1.amazonaws.com [34.195.121.130] with 32 bytes of data:
Response from 34,195,121,130: bytes = 32 time = 152ms TTL = 41
Response from 34,195,121,130: bytes = 32 time = 151ms TTL = 41
Response from 34,195,121,130: bytes = 32 time = 158ms TTL = 41
Response from 34,195,121,130: bytes = 32 time = 155ms TTL = 41
Ping statistics for 34,195,121,130:
Packages: sent = 4, received = 4, lost = 0
(0% lost),
Approximate times of return in milliseconds:
Minimum = 151ms, Maximum = 158ms, Mean = 154ms
What do I do now?
Thank you
