Problem with npm install
Hi.
after runing npm install got error and nod_modules couldn’t be install. I got this error:
npm ERR! gyp ERR! node -v v14.16.0
npm ERR! gyp ERR! node-gyp -v v7.1.2
npm ERR! gyp ERR! Node-gyp failed to build your package.
npm ERR! gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
Thanks for any help
Hi @Samir_Talic_39646, welcome to the community.
Seems like you are using a really old version of Node & npm, can you please execute the following commands:
node -v
npm -v
Once executed, please reply to this post along with their respective outputs.
Thanks and Regards.
Sourabh Bagrecha,
Curriculum Services Engineer
Hi
node v14.16.0 and npm 7.12.0
Regards
I am not really sure what is causing this error, can you try installing the windows-build-tools as well?
Do the following, in the same order as mentioned:
  1. Remove the node_modules folder inside the project folder where the package.json file is located, if it’s already there.
  2. Run npm update -g npm
  3. Execute this command by running the command prompt as Administrator npm install -g windows-build-tools
  4. Run npm install inside the project folder where the package.json file is located, if it doesn’t work run: npm install --force
Thanks and Regards.
Sourabh Bagrecha,
