Problem on the first question
I am working on the Lab: " Creating First Application User".
For the first part:
Connect to a mongod instance that is already running in the background on port 27000 . You can find the options used to launch mongod in the configuration file in your file editor.
I already tried a number of different ways to connect, but nothing works.
I am obviously missing something. It may be easy … but how can we connect?
Hi @Michel_Bouchet
would you add what command are you running?
Use mongo --port 27000 or it will try to connect to 27017
Well I tried several, first using the mongod command (with port 27000 ). Then I thought I should use mongo instead in this situation, because mongod is already running and mongo is probably what I need here. But in all cases it failed. …
I just retried a new one:
mongo -u m103-dmin -p m103-pass --port 27000 --authenticationDatabase admin
It looks like it is now finally working.
Thanks a lot for you reply.
