According to mongodb atlas cluster api, the get request should return connection strings with the following property “privateSrv”, if : Atlas returns this parameter only if you created a network peering connection to this cluster.
I have created network peering between my AWS vpc and atlas mongodb created network container (VPC) On both sides the vpc connection shows Active/Available state. I have also upgraded to M10 dedicated cluster.
However the get request only returns “standard” and “standardSrv” connection strings in “connectionStrings” object.
Is there anything else I can do (any step I have forgotten to do)? Is there a way to make cluster aware of the peering? Without privateSrv connectionString the whole peering is useless.
thanks
Simon
