Please, need help to error - Site down
{“t”:{“$date”:“2024-02-06T15:02:00.543-03:00”},“s”:“I”, “c”:“NETWORK”, “id”:4712102, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“Host failed in replica set”,“attr”:{“replicaSet”:“PrdBuzzFeedConfigReplicaSet”,“host”:“ip-172-31-34-36.sa-east-1.compute.internal:27017”,“error”:{“code”:6,“codeName”:“HostUnreachable”,“errmsg”:“Error connecting to ip-172-31-34-36.sa-east-1.compute.internal:27017 (172.31.34.36:27017) :: caused by :: Connection refused”},“action”:{“dropConnections”:true,“requestImmediateCheck”:false,“outcome”:{“host”:“ip-172-31-34-36.sa-east-1.compute.internal:27017”,“success”:false,“errorMessage”:“HostUnreachable: Error connecting to ip-172-31-34-36.sa-east-1.compute.internal:27017 (172.31.34.36:27017) :: caused by :: Connection refused”}}}}
{“t”:{“$date”:“2024-02-06T15:02:00.543-03:00”},“s”:“I”, “c”:“-”, “id”:4333222, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“RSM received failed isMaster”,“attr”:{“host”:“ip-172-31-34-36.sa-east-1.compute.internal:27017”,“error”:“HostUnreachable: Error connecting to ip-172-31-34-36.sa-east-1.compute.internal:27017 (172.31.34.36:27017) :: caused by :: Connection refused”,“replicaSet”:“PrdBuzzFeedConfigReplicaSet”,“isMasterReply”:“{}”}}
{“t”:{“$date”:“2024-02-06T15:02:00.542-03:00”},“s”:“I”, “c”:“CONNPOOL”, “id”:22576, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“Connecting”,“attr”:{“hostAndPort”:“ip-172-31-34-36.sa-east-1.compute.internal:27017”}}
{“t”:{“$date”:“2024-02-06T15:02:00.380-03:00”},“s”:“I”, “c”:“NETWORK”, “id”:4712102, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“Host failed in replica set”,“attr”:{“replicaSet”:“PrdBuzzFeedConfigReplicaSet”,“host”:“ip-172-31-45-163.sa-east-1.compute.internal:27017”,“error”:{“code”:6,“codeName”:“HostUnreachable”,“errmsg”:“Error connecting to ip-172-31-45-163.sa-east-1.compute.internal:27017 (172.31.45.163:27017) :: caused by :: Connection refused”},“action”:{“dropConnections”:true,“requestImmediateCheck”:false,“outcome”:{“host”:“ip-172-31-45-163.sa-east-1.compute.internal:27017”,“success”:false,“errorMessage”:“HostUnreachable: Error connecting to ip-172-31-45-163.sa-east-1.compute.internal:27017 (172.31.45.163:27017) :: caused by :: Connection refused”}}}}
{“t”:{“$date”:“2024-02-06T15:02:00.380-03:00”},“s”:“I”, “c”:“-”, “id”:4333222, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“RSM received failed isMaster”,“attr”:{“host”:“ip-172-31-45-163.sa-east-1.compute.internal:27017”,“error”:“HostUnreachable: Error connecting to ip-172-31-45-163.sa-east-1.compute.internal:27017 (172.31.45.163:27017) :: caused by :: Connection refused”,“replicaSet”:“PrdBuzzFeedConfigReplicaSet”,“isMasterReply”:“{}”}}
{“t”:{“$date”:“2024-02-06T15:02:00.379-03:00”},“s”:“I”, “c”:“CONNPOOL”, “id”:22576, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“Connecting”,“attr”:{“hostAndPort”:“ip-172-31-45-163.sa-east-1.compute.internal:27017”}}
{“t”:{“$date”:“2024-02-06T15:02:00.175-03:00”},“s”:“I”, “c”:“NETWORK”, “id”:4712102, “ctx”:“ReplicaSetMonitor-TaskExecutor”,“msg”:“Host failed in replica set”,“attr”:{“replicaSet”:“PrdBuzzFeedConfigReplicaSet”,“host”:“ip-172-31-7-45.sa-east-1.compute.internal:27017”,“error”:{“code”:6,“codeName”:“HostUnreachable”,“errmsg”:“Error connecting to ip-172-31-7-45.sa-east-1.compute.internal:27017 (172.31.7.45:27017) :: caused by :: Connection refused”},“action”:{“dropConnections”:true,“requestImmediateCheck”:false,“outcome”:{“host”:“ip-172-31-7-45.sa-east-1.compute.internal:27017”,“success”:false,“errorMessage”:“HostUnreachable: Error connecting to ip-172-31-7-45.sa-east-1.compute.internal:27017 (172.31.7.45:27017) :: caused by :: Connection refused”}}}}
  1. This is a community managed forum if you need critical support, opening a support ticket is the best way to get help. https://support.mongodb.com/
  2. It looks like these hosts isn’t available, I would check that the MongoDB process is running successfully on the host, the host is reachable. If the nodes and processes are up I would verify they can communicate over port 27017
  1. What is the topology of the database? A replica set?
Yes, 1 primary, 2 secondary.
