I have a class hierarchy with base and derived classes in C#.
The BsonId is stored on the base class and the derived classes hold some additional data.
I have an additional Id field on the derived class used for other purposes, and I set up the BsonClassMap to map it to “Id”, so it shouldn’t conflict with the BsonId.
I want to run a pipeline to make a query on the “derived” collection, but the pipeline fails to render to Bson.
The issue may be that ExpressionToAggregationExpressionTranslator creates a new BsonClassMap with AutoMap() and does not use the registered BsonClassMaps.
Code:
using MongoDB.Bson;
using MongoDB.Bson.Serialization;
using MongoDB.Bson.Serialization.Attributes;
using MongoDB.Driver;
BsonClassMap.RegisterClassMap<Derived>(cm =>
cm.AutoMap();
cm.UnmapProperty(x => x.Id);
cm.MapProperty(x => x.Id).SetElementName(nameof(Derived.Id));
}).Freeze();
var pipeline = new EmptyPipelineDefinition<Derived>()
.Project(x => new Derived
Id = x.Id,
var rendered = pipeline.Render(BsonSerializer.SerializerRegistry.GetSerializer<Derived>(), BsonSerializer.SerializerRegistry);
Console.WriteLine(rendered);
public abstract class Base
[BsonId]
[BsonElement("_id")]
public ObjectId UniqueId { get; set; }
public class Derived : Base
[BsonElement("Id")]
public string Id { get; set; }
Exception:
MongoDB.Bson.BsonSerializationException: The property 'Id' of type 'Derived' cannot use element name '_id' because it is already being used by property 'UniqueId' of type 'Base'.
at MongoDB.Bson.Serialization.BsonClassMap.Freeze()
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToAggregationExpressionTranslators.MemberInitExpressionToAggregationExpressionTranslator.Translate(TranslationContext context, MemberInitExpression expression)
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToAggregationExpressionTranslators.ExpressionToAggregationExpressionTranslator.Translate(TranslationContext context, Expression expression)
at MongoDB.Driver.Linq.Linq3Implementation.Translators.ExpressionToAggregationExpressionTranslators.ExpressionToAggregationExpressionTranslator.TranslateLambdaBody(TranslationContext context, LambdaExpression lambdaExpression, IBsonSerializer parameterSerializer, Boolean asRoot)
at MongoDB.Driver.Linq.Linq3Implementation.LinqProviderAdapterV3.TranslateExpressionToProjection[TInput,TOutput](Expression`1 expression, IBsonSerializer`1 inputSerializer, IBsonSerializerRegistry serializerRegistry, ExpressionTranslationOptions translationOptions)
at MongoDB.Driver.ProjectExpressionProjection`2.Render(IBsonSerializer`1 inputSerializer, IBsonSerializerRegistry serializerRegistry, LinqProvider linqProvider)
at MongoDB.Driver.PipelineStageDefinitionBuilder.<>c__DisplayClass39_0`2.<Project>b__0(IBsonSerializer`1 s, IBsonSerializerRegistry sr, LinqProvider linqProvider)
at MongoDB.Driver.DelegatedPipelineStageDefinition`2.Render(IBsonSerializer`1 inputSerializer, IBsonSerializerRegistry serializerRegistry, LinqProvider linqProvider)
at MongoDB.Driver.AppendedStagePipelineDefinition`3.Render(IBsonSerializer`1 inputSerializer, IBsonSerializerRegistry serializerRegistry, LinqProvider linqProvider)
at MongoDB.Driver.PipelineDefinition`2.Render(IBsonSerializer`1 inputSerializer, IBsonSerializerRegistry serializerRegistry)
at Program.<Main>$(String[] args) in C:\src\MongoTest\MongoTest\Program.cs:line 19
