I was trying to install mogodb on fedora 36 using this
and then sudo dnf install mongodb-org mongodb-org-server
but now when i try to run mongod
i get this
$ mongod {"t":{"$date":"2022-06-22T15:21:27.818+05:30"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"} {"t":{"$date":"2022-06-22T15:21:27.825+05:30"},"s":"W", "c":"ASIO", "id":22601, "ctx":"main","msg":"No TransportLayer configured during NetworkInterface startup"} {"t":{"$date":"2022-06-22T15:21:27.825+05:30"},"s":"I", "c":"NETWORK", "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"I", "c":"STORAGE", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":26029,"port":27017,"dbPath":"/data/db","architecture":"64-bit","host":"fedora"}} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"4.4.15","gitVersion":"bc17cf2c788c5dda2801a090ea79da5ff7d5fac9","openSSLVersion":"OpenSSL 1.1.1n FIPS 15 Mar 2022","modules":[],"allocator":"tcmalloc","environment":{"distmod":"rhel80","distarch":"x86_64","target_arch":"x86_64"}}}} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"Fedora release 36 (Thirty Six)","version":"Kernel 5.18.5-200.fc36.x86_64"}}} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{}}} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"E", "c":"STORAGE", "id":20557, "ctx":"initandlisten","msg":"DBException in initAndListen, terminating","attr":{"error":"NonExistentPath: Data directory /data/db not found. Create the missing directory or specify another path using (1) the --dbpath command line option, or (2) by adding the 'storage.dbPath' option in the configuration file."}} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"I", "c":"REPL", "id":4784900, "ctx":"initandlisten","msg":"Stepping down the ReplicationCoordinator for shutdown","attr":{"waitTimeMillis":10000}} {"t":{"$date":"2022-06-22T15:21:27.826+05:30"},"s":"I", "c":"COMMAND", "id":4784901, "ctx":"initandlisten","msg":"Shutting down the MirrorMaestro"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"SHARDING", "id":4784902, "ctx":"initandlisten","msg":"Shutting down the WaitForMajorityService"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"NETWORK", "id":20562, "ctx":"initandlisten","msg":"Shutdown: going to close listening sockets"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"NETWORK", "id":4784905, "ctx":"initandlisten","msg":"Shutting down the global connection pool"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"STORAGE", "id":4784906, "ctx":"initandlisten","msg":"Shutting down the FlowControlTicketholder"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"-", "id":20520, "ctx":"initandlisten","msg":"Stopping further Flow Control ticket acquisitions."} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"NETWORK", "id":4784918, "ctx":"initandlisten","msg":"Shutting down the ReplicaSetMonitor"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"SHARDING", "id":4784921, "ctx":"initandlisten","msg":"Shutting down the MigrationUtilExecutor"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"CONTROL", "id":4784925, "ctx":"initandlisten","msg":"Shutting down free monitoring"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"STORAGE", "id":4784927, "ctx":"initandlisten","msg":"Shutting down the HealthLog"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"STORAGE", "id":4784929, "ctx":"initandlisten","msg":"Acquiring the global lock for shutdown"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"-", "id":4784931, "ctx":"initandlisten","msg":"Dropping the scope cache for shutdown"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"FTDC", "id":4784926, "ctx":"initandlisten","msg":"Shutting down full-time data capture"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"CONTROL", "id":20565, "ctx":"initandlisten","msg":"Now exiting"} {"t":{"$date":"2022-06-22T15:21:27.827+05:30"},"s":"I", "c":"CONTROL", "id":23138, "ctx":"initandlisten","msg":"Shutting down","attr":{"exitCode":100}}
