I am currently trying to create a automated test. One step is to verify in mongoDB. I have the SRV connection string and was able to connect to the cluster using Robo3T so i guess the credentials are fine.
I tried creating a function in my java project to connect to mongoDB but was having error:
INFO org.mongodb.driver.cluster - Exception in monitor thread while connecting to server XXXXXXX.mongodb.net:1058
com.mongodb.MongoSocketWriteException: Exception sending message
at com.mongodb.internal.connection.InternalStreamConnection.translateWriteException(InternalStreamConnection.java:550)
at com.mongodb.internal.connection.InternalStreamConnection.sendMessage(InternalStreamConnection.java:432)
at com.mongodb.internal.connection.InternalStreamConnection.sendCommandMessage(InternalStreamConnection.java:272)
at com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:256)
at com.mongodb.internal.connection.CommandHelper.sendAndReceive(CommandHelper.java:83)
at com.mongodb.internal.connection.CommandHelper.executeCommand(CommandHelper.java:33)
at com.mongodb.internal.connection.InternalStreamConnectionInitializer.initializeConnectionDescription(InternalStreamConnectionInitializer.java:105)
at com.mongodb.internal.connection.InternalStreamConnectionInitializer.initialize(InternalStreamConnectionInitializer.java:62)
at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:129)
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:117)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: javax.net.ssl.SSLException: Connection reset
at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:127)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:350)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:293)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:288)
at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:144)
at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1408)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1314)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:440)
at java.base/sun.security.ssl.SSLSocketImpl.ensureNegotiated(SSLSocketImpl.java:819)
at java.base/sun.security.ssl.SSLSocketImpl$AppOutputStream.write(SSLSocketImpl.java:1189)
at com.mongodb.internal.connection.SocketStream.write(SocketStream.java:99)
at com.mongodb.internal.connection.InternalStreamConnection.sendMessage(InternalStreamConnection.java:429)
… 9 more
Suppressed: java.net.SocketException: Connection reset by peer: socket write error
at java.base/java.net.SocketOutputStream.socketWrite0(Native Method)
at java.base/java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:110)
at java.base/java.net.SocketOutputStream.write(SocketOutputStream.java:150)
at java.base/sun.security.ssl.SSLSocketOutputRecord.encodeAlert(SSLSocketOutputRecord.java:81)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:381)
… 19 more
Caused by: java.net.SocketException: Connection reset
at java.base/java.net.SocketInputStream.read(SocketInputStream.java:186)
at java.base/java.net.SocketInputStream.read(SocketInputStream.java:140)
at java.base/sun.security.ssl.SSLSocketInputRecord.read(SSLSocketInputRecord.java:476)
at java.base/sun.security.ssl.SSLSocketInputRecord.readHeader(SSLSocketInputRecord.java:470)
at java.base/sun.security.ssl.SSLSocketInputRecord.decode(SSLSocketInputRecord.java:160)
at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:110)
… 16 more
