MongoDb Basics Lab1 Connection Error
Hi. I am unable to connect to Atlas with the following command in Lab1:
mongo “mongodb+srv://cluster0.xofhi.mongodb.net/myFirstDatabase” --username m001-student. Here is the output display:
2 total, 0 passed, 0 skipped:
[FAIL] “Successfully connected to the Atlas Cluster”
Did you use the right command with the Atlas provided connection string?
[FAIL] “The username is m001-student”
Did you create a username m001-student?
Please help, Thanks.
Post a screenshot of the IDE that shows where and how you entered the command.
The connection string is correct.
Did you get any error when you entered the command?
You might have enter the command in the wrong area, perhaps in the file editor area rather than the terminal. You might have forget to press the ENTER key at the end of the command.
From the lab description:
and hitting “enter/return” on your keyboard.
And from a previous post:
got it, thank you very much
