Hi All,
I have created an account on MongoDB Atlas and tried connecting to MongoDB Atlas Cluster using the Java code.
With the same java code I am able to connect to On-Premise MongoDB but not the Atlas Cluster.
INFO: Exception in monitor thread while connecting to server ssc-cluster-01-shard-00-02.9cbnp.mongodb.net:27017
com.mongodb.MongoSocketWriteException: Exception sending message
at com.mongodb.internal.connection.InternalStreamConnection.translateWriteException(InternalStreamConnection.java:525)
at com.mongodb.internal.connection.InternalStreamConnection.sendMessage(InternalStreamConnection.java:413)
at com.mongodb.internal.connection.InternalStreamConnection.sendCommandMessage(InternalStreamConnection.java:269)
at com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:253)
at com.mongodb.internal.connection.CommandHelper.sendAndReceive(CommandHelper.java:83)
at com.mongodb.internal.connection.CommandHelper.executeCommand(CommandHelper.java:33)
at com.mongodb.internal.connection.InternalStreamConnectionInitializer.initializeConnectionDescription(InternalStreamConnectionInitializer.java:106)
at com.mongodb.internal.connection.InternalStreamConnectionInitializer.initialize(InternalStreamConnectionInitializer.java:63)
at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:127)
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:117)
at java.lang.Thread.run(Thread.java:745)
Caused by: javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: No subject alternative names matching IP address 13.235.32.72
