Mongo shell connection error to Atlas cluster
I created a new MongoDB user, and allowed connections from anywhere in the IP Whitelist section.
I tried to connect using the CLI from windows 10, but I got a connection error.
This is the command:
mongo “mongodb+srv://cluster0-mpoaq.mongodb.net/test” --username m001-student
the cluster name is Cluster0 and the user I have created has the following credentials: username:m001-student
password:m001-mongodb-basics
after entering the password I got this error:
socket exception [CONNECT_ERROR] server [cluster0-shard-00-02-mpoaq.mongodb.net:27017] connection pool error: network error while attempting to run command ‘isMaster’ on host ‘cluster0-shard-00-02-mpoaq.mongodb.net:27017
The mongoDB shell version is 4.0.6
any help is appreciated
Thank you!
I think in your CLI you forgot to type the password in the command.
instead of:
use:
mongo “mongodb+srv://cluster0-mpoaq.mongodb.net/test” --username m001-student --password m001-mongodb-basics
Hi Abdul, thanks for the reply.
I forgot to mention that, after launching that command, the CLI requests the password. After entering it, I got the error
switching to another network solved the problem. Thanks a lot
I have a similar issue. I tried mongo “mongodb+srv://cluster0-mpoaq.mongodb.net/test” --username m001-student --password m001-mongodb-basics.
But I get this result instead. How do I correct it?
The full view is image
Already responded in other thread
Ignore those warning messages
You are already at mongo prompt which means successfully connected to mongodb
