Hi
Problem Statement
I am currently attempting to establish a connection with MongoDB using the IAM Role as described here -https://www.mongodb.com/docs/atlas/security/passwordless-authentication/ . The problem statement is that I am unsure of the process required to ensure the connection works from an AWS perspective using Lambda.
Background info
I’ve created an IAM Role using AWS SAM.
MongoDBReadWriteAccess:
Type: AWS::IAM::Role
Properties:
RoleName: MongoDBReadWriteAccess
AssumeRolePolicyDocument:
Version: '2012-10-17'
Statement:
- Effect: Allow
Principal:
AWS: arn:aws:iam::<atlast aws account ID>:root
Action: sts:AssumeRole
Condition:
StringEquals:
sts:ExternalId: <external ID>
I attempt to retrieve the keys from the env variables in my application logic
aws_access_key_id = os.getenv("AWS_ACCESS_KEY_ID")
aws_secret_access_key = os.getenv("AWS_SECRET_ACCESS_KEY")
aws_session_token = os.getenv("AWS_SESSION_TOKEN")
I create the connection
url_connection = f"mongodb+srv://{access_key_URI}:{secret_key_URI}@{server_name}.ozmat.mongodb.net/?authSource=%24external&authMechanism=MONGODB-AWS&retryWrites=true&w=majority&authMechanismProperties=AWS_SESSION_TOKEN:{session_token_URI}"
However the role that I created isn’t the assumed role at execution time.
OperationFailure: bad auth : user arn:aws:sts::<id>:assumed-role/<incorrect_role_name>/* is not found, full error: {'ok': 0, 'errmsg': 'bad auth : user arn:aws:sts::<id>:assumed-role/<incorrect_role_name> is not found', 'code': 8000, 'codeName': 'AtlasError'}
I’ve attempted to assign the role using SAM
StepPlanCRUD:
Type: AWS::Serverless::Function # More info about Function Resource: https://github.com/awslabs/serverless-application-model/blob/master/versions/2016-10-31.md#awsserverlessfunction
Properties:
PackageType: Image
Architectures:
- x86_64
Role: !GetAtt MongoDBReadWriteAccess.Arn
but I get the following error on deploy:
"The role defined for the function cannot be assumed by Lambda. (Service: Lambda, Status Code: 400, ...
Please can somebody detail the steps required in order to allow connectivity between Lambda and Atlas from an AWS perspective?
