Lab - Using $lookup
Hi guys,
I have successfully solved the problem, the issue that I saw is in aggregation within $match I am using $in to check filter document however in solution its done using filter. And the count of the result is different.
I have also compared my query with the detailed answer query and the only difference I saw was around $match.
Can someone explain, what I missed by not using Regex.
Thanks in advance.
I had the same issue but instead I was using $or and I got different counts.
EDIT: It turns out that the field airplane could have values like: โ€œ747 380 320โ€ which cannot be matched with exact โ€œ747โ€ or โ€œ380โ€.
That is why we need to use regex /747|380/
@Ivo_02187 Thanks mate :slight_smile:
