Lab - Using Cursor-like Stages : Problem with $skip
The question asks for 25th film as below:
For movies released in the USA with a tomatoes.viewer.rating greater than or equal to 3, calculate a new field called num_favs that represets how many favorites appear in the cast field of the movie.
Sort your results by num_favs, tomatoes.viewer.rating, and title, all in descending order.
What is the title of the 25th film in the aggregation result?
I wrote the pipeline and I added { $skip: 24} at the end. The result was “Up in the Air”, which was not among the answers. Then I remove the { $skip: 24}, counted the results to 25. And the 25th title was “The Heat”, which was correct.
Then, I checked the detailed answer, which was similar to my first pipeline. I run through the pipeline and even the correct answer resulted in “Up in the Air”.
Why does this happen? I’ve no clue.
Hi @Serhat_Demirkol, we would need to see the query you wrote to help you understand what is going on. Without that it’s only a guess.
Hi, This is the query I wrote which results in “Up In the Air”.
var favorites = [
  "Sandra Bullock",
  "Tom Hanks",
  "Julia Roberts",
  "Kevin Spacey",
  "George Clooney"]
db.movies.aggregate([
    $match: {
      "tomatoes.viewer.rating": { $gte: 3 },
      countries: "USA",
      cast: {
        $in: favorites
    $project: {
      _id: 0,
      title: 1,
      "tomatoes.viewer.rating": 1,
      num_favs: {
        $size: {
          $setIntersection: [
            "$cast",
            favorites
    $sort: { num_favs: -1, "tomatoes.viewer.rating": -1, title: -1 }
    $skip: 24
Then I remove $skip part :
var favorites = [
  "Sandra Bullock",
  "Tom Hanks",
  "Julia Roberts",
  "Kevin Spacey",
  "George Clooney"]
    $match: {
      countries: "USA",
      cast: {
        $in: favorites
    $project: {
      _id: 0,
      title: 1,
      num_favs: {
        $size: {
          $setIntersection: [
            "$cast",
            favorites
After I found “The Heat” as the 25th title, I checked the answer (see it below) , which results in “Up In The Air”
var favorites = [
  "Sandra Bullock",
  "Tom Hanks",
  "Julia Roberts",
  "Kevin Spacey",
  "George Clooney"]
    $match: {
      countries: "USA",
      cast: {
        $in: favorites
    $project: {
      _id: 0,
      title: 1,
      num_favs: {
        $size: {
          $setIntersection: [
            "$cast",
            favorites
    $skip: 24
    $limit: 1
I get The Heat with all 3 queries.
Perhaps your query was a little bit different at first.
